I would like to get my Z3 alarm working again. The little light flashes but I have no way to turn the alarm on or off. Does anyone have a keyfob available that I can code to my car?
I have no fob at the moment, the light I talk about is the one in the car, the little alarm light. It flashes when I start the car, etc but doesn't flash to say it is armed when I lock the car with the key so figuring I need the remote fob to activate it.Try @spurs fan in a coupe - he did have loads. If the light on your existing flashes then you could try to re-program it - or it may need a new battery if signal is weak.
Locking the car with the key will not set/unset the alarm - the key is for central locking only. The panel light should only flash when the alarm is set with the remote (which I now understand you do not have).I have no fob at the moment, the light I talk about is the one in the car, the little alarm light. It flashes when I start the car, etc but doesn't flash to say it is armed when I lock the car with the key so figuring I need the remote fob to activate it.
1997Richard - what year was your car produced? Just checking we are talking about same system version.
Ok - should be the same as mine then and the info I gave you above should apply.1997
Yes - you need a key fob but the mystery is that the LED flashes when you start the car. It doesn't make complete sense but it is possible the alarm is set but switched off under the bonnet. If it is you need a special key to switch it back on. See pics for infoSo I need a key fob to be able to play with this. I went to sytners and asked about master key and supposedly for my car the can provide a master key with buttons that will control the alarm and the central locking. Not sure if that is correct so want to try a fob first.
