Carpet mat clips secures moving
Gary Coppell
Need some help 🙏 my carpet mat secure doesn’t locate in the carpet it just spins due to the foam underneath.
Anyone else had this problem and cured it ?
I was thinking expanding foam then relocating hoping it stays where it should but open to other suggestions
Neilb62
Darwen
3.0 Roadster.
I fixed mine using a large rawlplug, it’s holding so far 🤞
The original Mats have a fixing kit.
You could buy an aftermarket fixing kit and secure the mat with them
Mario
This might seem like an overkill but cured mine for sure, its quite involved though, what I did is remove the seat (2 bolts 2 nuts) and then with the seat out of the car lift the carpets then I made a plate out of flexible plastic for a relatively good size i.e. 4 or 5 cm diameter for each hook on each side 4 in total (from containers you have at home like old oil bottles) and drilled a small hole and used it as a backplate to screw the original hooks through it it so it prevents them from backing off the foam underneath again - years of no trouble
