Clutch Switch
rmoconnor41
Checking for fault codes today after the 2.8 had been throwing up various codes indicating air leaks and 02 sensor issues.
They now appear to have been resolved but I checked today and got a
Clutch Switch 26 fault.
Not a fault I have come across before. Any ideas?
Thanks.
Mike Fishwick
French Zeds
Daglan, France
A faulty clutch switch can cause the engine rpm to rise by about 1500 rpm during gear changes - my 2.8 had this problem at about 12000 miles, and was fitted with a modified switch and wiring.
Dino D
Kent
2.8 Manual
That’s interesting- could it be the cause is the ‘rev hang’ some cars exhibit?
Is its TU engine only thing or is on all cars - cable throttle and fly by wire?
Rudyrov
Phoenix, AZ
2.8 L Roadster
From what I can tell. one side of the clutch switch goes to the cruise control, however the other side should probably be a ground for the starter circuit. Does anybody have a good copy of the wiring Diagram? I only have the troubleshooting one.
Thanks!
