Tomk
- Mar 8, 2023
Looking to fit my new single mass clutch at the weekend anybody tried one of these budget alignment tools?
Any issues fitting flywheel?Most standard clutches you can align by your finger tips and eyes. There will be 3 points where you can see the pressure plate and driven plate. Attach the cover with screws only finger tight put a large screwdriver through the driven plate into the spigot bearing and move the driven plate until it is centered with the pressure plate. Then tighten the cover bolts.
Thanks Tony.No issues fitting a flywheel. Bolt spacing normally ensured it's in the right place or all the bolts (6?) won't screw in by hand.
Ironically I’ve been saving a shaft for near 20 years for this occasion, typically I now can’t find itThe best clutch alignment tool is a first motion shaft from a scrap gearbox.
Have new ones, bought a full kit.I may be misremembering, but are the flywheel bolts single-use only? May have got them confused with some other car, but there's something in my mind about them being stretch bolts.
Time was I had the 1st motion shots from several gearboxes cut down to make clutch alignment tools.Ironically I’ve been saving a shaft for near 20 years for this occasion, typically I now can’t find it![]()
ThanksUsually new flywheels come with new bolts .
I have been in motor trade nearly 40 yrs now probably fitted 50 plus clutches in that time one thing i Dont have in my tool kit is a clutch lining kit never used one as Tony has said most clutch kits there is 3 points where you can see the friction plate position in relation to the cover plate to line it up
If you really want to use something to assist you then a half inch drive extension with some insulation tape wrapped round to make correct diameter.
It is important to make sure it is lined up as if out even by a small amount will make the gearbox an absolute pig to reinstall.
I like your approach TonyIf you got the box back in OK it couldn't have been far out, and, once the clutch has been operated a couple of times, it is spot on anyway.
