E89 Dash Cam Fitting
Have any of you e89 owners hard wired a dash cam in? Was wondering where you took the feed from for ignition activation?
Thanks for that but I have a hard wire kit so going straight to the fuse box on a piggy back fuse just wanted an ACC fuse.
Oddly Godly
dunstable
z3 2.8
I couldn't find a route through to the fuse box on my z3. I remembered there was a fuse on the back of the car radio I fitted and used that instead.
AleNod
Huddersfield, West Yorkshire
Z4 E89 20i sdrive roadster
I did do exactly that Niall, there is one there but I've forgotten which one ! If you're stuck I can pull it out and check . . .
I just pulled the fuse box down and found an ignition fed fuse.
