To start this winters Zedshed season we took in @Davester2.2sport
Dave was complaining about the normal wobbly rear end and odd handling characteristics and some rust
In the weeks leading to D-day we thrashed out a list of parts with rough costing so this build will replace the following:
* Rear Beam Bushes x2
* Rear Drop Links x2
* Rear shocks x2 (Sachs)
* Rear Top Mounts x2
* Diff Bush (Powerflex)
* Rear Back plates x2
* Handbrake cables x2
* Rear Discs + Pads + Handbrake Shoes x2 (Brembo)
* Front shocks x2 (Sacks)
* Front Wishbones (Meyle HD)
* Front Drop Links
So quite the list, I'll let the first day of pictures do most of the talking.
D-Day - Step 1 is to get the zed high enough to remove the wheels and wheel the other crap outside
First look underneath showed a very rusty looking zed. Think it must have been a sea side car. One side had a new shock and old spring, the other side had a new spring (not z3 spring) toast shock. Madness what people do with their cars. Also one side the back plate was rotten.
Can confirm the bushes were shot, they were both sat on the plate.
This car proved very testing, with all the corrosion most bolts snapped or heads rounded. The norm for us is 2/3hours to strip down this took 4/5 hours. (Photo brake lines blanked)
Finally everything removed, we had to opt for the separation method of removing each swing arm with shaft and diff with beam.
Can confirm the bushes were toast
Closer inspection showed the springs weren't the same.
Me and Gaz pulled some extra time in the garage today. This is what was left of the nearside backing plate.
See Part 2 for more
* Front Drop Links
See Part 2 for more
