Anyone selling them? Looking for the under-the-seat brackets, clamps (or equivalent), plus the fire extinguisher. Thank you.
Thank you @AntStark . Do you have the clamps snd the bracket too? Im after one that works tbh.I have got one mate, genuine bmw ..can’t guarantee it would work mind. Yours if you want it
Ah, awesome if you can find the spare! Please let me know if you find it. Thanks!Me?
No, no brackets, my lads has just said he threw the spare ext out as it was solid.
I made brackets to fit the seat that takes a new modern extinguisher with a gauge.
I’ll have a look at the weekend, I’m sure I made a spare.
Yes I think I have all the fixings still ..will check. I am not sure how you check it’s working other than to use itThank you @AntStark . Do you have the clamps snd the bracket too? Im after one that works tbh.
PM'd you sir
Why, oh why, do I expect this from you, @MazzaI used an extinguisher on a mini many years ago …. had no effect on the fire in the engine and the whole car ended up in flames … till the fire engine turned up … but too late to save it![]()
I do have that bracket, it would need rivnuts inserted into the seat, designed to hold a 2kg extinguisher.Ah, awesome if you can find the spare! Please let me know if you find it. Thanks!
Thank you so much @Mazza - I'll ping you once I've collected the item(s) from @AntStarkI have loads of rivnuts if you need a couple, and you can fit them without the proper tool just by using a long hex head bolt and a couple of washers and nuts.
If you go that route then pm me with your address and what size rivnuts you need and I’ll stick them in the post.
