Front suspension
D R Oldfield
Barrow-in-Furness
HI i want to drop the front suspenson and subframe on my 2.8 Z3 is the best way to support the the engine to use a engine support across the inner wings?
any thoughts
thanks
Scooblitz
Glasgow, Scotland
any thoughts
thanks
Yes.
What job are you planning on doing?
D R Oldfield
Barrow-in-Furness
basically to do a full refurbish of the front end drop the crossmember and strip it get it sandblasted and powdercoated and investigate a leak on the power steering rack ,
Scooblitz
Glasgow, Scotland
Unless powercoating the front subframe itself and perhaps replacing the engine mounts, it’s maybe not needed to get the ole’ engine brace out and to investigate a steering fluid leak.
You could still get a big refresh done unbuttoning from the top mounts, to the rear lollipops, anti roll bar and track/tie rod ends.
Are you going full scale? knuckles getting power coated, new abs rings, bearings etc?
Stevie
