Help please
S54addict
S54 Z3M, Z4M coupe/roadster
so I thought I would get the Z4m coupe out this weekend after her sleep. But, unfortunately on turning the key all I got was a click, no lights dimming and battery is good. I presume the starter motor?? Any ideas? I understand it's a bit of a pain job as you need to remove the air intake manifold. Any advice appreciated
Thxs
Before doing that try putting the car in gear and rock the car in case the starter has stuck in mesh.
DavidM
Ireland
How good is the battery? Don’t rule it out if the car has been off the road for some time.
S54addict
thxs for the info guys.
I towed the car with my truck and she started by bump straight away. Would this have the same effect as rocking?? Car is stored in a dry garage, and terminals look clean. Also gave starter a good spray of WD40
S54addict
Lights don't dim on key turn. Either?
If it happens again connect a jump lead between the earth point under the bonnet and the engine block. This will eliminate engine earth fault.
S54addict
Just got starter off, once googled it only took 20 mins. So will get it checked tomoz :thumbsup:
S54addict
Dropped off starter, waiting for the verdict ...
S54addict
It was the solenoid... Not too bad, £60 :thumbsup:
