Oil leak from a gear box
Kenya
Dear friends,
I found the old leak from the gearbox. See the attached. Can you advise me how yo fix this ?
Regards
Looks like its a gearbox out job to find the source of the leak, most probably the output shaft oil seal leaking and finding its way to the joint you circled.
2 litre parts diagram here for info but check Realoem site using last seven of your cars vin number for correct diagram
