Oil
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
Hi,
I personally use 5W40, because I use the car only 6 months, in the summer.
Most of the recommendation goes also for 0W30, for all season use.
For the hydraulic tappets probably the 0W30 it's better...
pgunter
Winchester
2.2i Sport Zedshed Special
I use 0W30 Fully Synthetic in my 2.2i Seems like she has been drinking that stuff most of her life from the service records.
Z
zedonist
Guest
Fuchs Titan supersyn 5w40is what I use in the M44, and is the recommended oil for the engine
jonco
Chester
'98 1.9 Auto
Fuchs titan Supersyn 5w40 is what you need
Agree - have just ordered my oils from Opie Oils - 5 litres about £26 plus delivery. If you go to Opie site and enter car details it will come up on recommended list.
Hammers
Hi zedonist I have a problem with the hydraulic tappers would the 0w 30 not help ?
Hammers
On start up its not firing on all four for about 30 seconds
I would be putting some flushing oil into what's already in the engine and run that for a while. Then change oil and filter regularly.
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
I found a dealer in RO for the Fuchs oil and the price is similar (of course without gloves, etc.); the option is 4+1 liter, the 5 liter is not available...
I will try it on the next oil change; till now I used only the ARAL 5W40, also made in Germany.:)
Z
zedonist
Guest
I would do what Tony says and try an engine flush, but if that does not work then I would replace the lifters, gunge just grows no matter how much you thin the oil out, and then you'll be into head problems
Kevin Cartwright
Greenville, SC
1.9 M44
I stick to the Manual specified weight of 15w-50 I prefer the Motul 6100 15w-50. I run an oil temp gauge setup by VDO to make sure i don't wind to aggressively until the oil has at least 160 degrees of temp.
