Try @ZEDonist UK mate, good kit, I have it on mineI’m going have to ring around dealers on Monday but wondering if any has had a price before from BMW for the high pressure PS pipe work?
Thanks Andy but I have had all of that fitted along with a new reservoir and the built in filter by my BMW specialist.
forums.m3cutters.co.uk
I was brain storming with Dino the other night over this, I could only think maybe change the power steering fluid for another brand they can vary in viscosity (Thickness).I am not sure how a hose could make noise or why a braded hose would solve the problem?
The pump is just a small hydraulic pump. Hoses simply connect it to the rack. The rack has valving in it that will increase the oil supply based on steering demand.
If it was only happening in one direction I would suspect it to be in the rack itself.
I'll dig the photos out when I'm home. I also shared these with Martin when he design these lines.I used to deal with modified systems in my old Jeeps for off road. They had high flow pumps and additional steering rams fitted. They would get very hot and make noise but it was always even in both directions.
All the power steering systems I have worked with had a check valve in the supply side. Normally it was a fitting on the outlet of the pump. I am not sure about the clear hose with holes in it and would only guess this would be to suppress flow related noises from the pump.
great points @Lee @DelkIf you turn the steering to full lock and keep pressure on the wheel does it continue to make a funny noise or does it stop?
When you are at full lock and hold the wheel the valves inside the steering rack will remain open and the pump and system will run at full pressure.
I used hedonist, got a great, quick service and good quality product.....I’m going have to ring around dealers on Monday but wondering if any has had a price before from BMW for the high pressure PS pipe work?
Thruxton is a quite a fast track no ?Saw this thread and thought I’d give another thumbs up for the Zedonist. (no association- just impressed with their product)
One of my steering pipes reputured on my 2.8 track car at Thruxton, which rather ruined the day
so whilst doing some repairs/replacement, I thought I’d replace the others.
ordered the one from the Zedonist
was very impressed with the kit that turned up.
everything included correct brackets, bolts washers etc and a quality bit of kit and was easy to fit on the car.
if you haven’t done so recently, you might want to check your steering pipes as you can see from the pictures of mine, the ones that didn’t blow at Thruxton were clearly on their last legs. They get the full force of all the grit stones and stuff thrown up from the road.
