Wanted Power steering hose / pipe 6 cylinder
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
I am in need of a power steering hose / pipe from a 6 cylinder model. Looking at the part number 32416754173 they are fitted to all facelift 6 cylinder models. Must be in good condition. Can breakers help? Possibly someone that is at Zedfest on Sunday and can bring along?
@spurs fan in a coupe
@mrscalex
@Synclare
Same as below
Thanks
mrscalex
Swindon & Swansea
I’m away until Monday. But if you haven’t sorted one by then I can have a look. 50:50 I would think. But send me a PM reminder Sunday if you still need it as I will forget otherwise.
Lee
Z4 Coupe 3.0si
They're all starting to split and leak now, I've got those fittings and hose in, looking to make up a cheaper fix in house.
Yours started leaking ?
g8jka
Telford, Shropshire
Yeah was leaking on the joint by where the nut screws in. Failed the MOT. My dad had the same issue a while back and a local company made up a temporary one which is fitted to mine at the moment. Just after one thats more original and routes around better.
Lee
Z4 Coupe 3.0si
Theres a double seal there, might get away with replacing those.
g8jka
Telford, Shropshire
Looks like it was coming from the curve where the pipe bends round due to corrosion and not the seal. Must have a very small split or hole in it.
  • Like
Reactions: Lee
