B
bonzo
Guest
Zelsa's door sills are getting a little bit ropey on the underside edges. Any good ones knocking about?
If so, let me know please!
Bonzo.
Bonzo.
Agree with repaint - did mine a 2 years ago but leading edges now need attention again - where and how do you do apply the 3M Rich?................. and put some 3m film on the leading edges when done
Do you know where one would find pattern part sills? I've only seen wings about.You can get new pattern parts but they are not coated with ecote, so will not last long, I would get a decent set of second hand parts and have repainted, will last years then, and put some 3m film on the leading edges when done
Getting them over here at a decent price is the problem...@Stormy_be can make them for you in fiberglass.
Yes Koen, I will have a pair please. No rush at all, but when do you think you will next be over?Hi all,
As said on other threads, I have made moulds from my own 2.8 pre-facelift sills.
I have made from these moulds my own sills in fiberglass.
Making more wouldn't be any problem.
Shipment depends on size and shape, so not cheap for sills.
But i do visit the uk from time to time (normally twice a year).
So if you don't need them very quickly, something might be possible to arrange.
Sills have a complex shape making that my moulds need repairing each time.
To reduce the repairs, the mould should bemade more rigid.
I can't make the moulds more rigid as the pieces wouldn't come out anymore (as the sills turn back on themselves, the mould need to remain more flexible)
I made mine in white gelcoat + 3 layers of 225gr grp. Which is more then enough. Even 2x 225 would have been enough (if weight is a crusial factor for you)
I use fiberglass that i source from a larger retailer, principally delevering for boat constructions.
So I know the base products are top quality.
Prices are 125€ (105-110£) each
Regards, Koen
