#ZedShed Siena Red 3.0 Front to Back
Lee
Z4 Coupe 3.0si
Now Daves Zed is back home we quickly in the next project. A lovely low mile (90k) 3.0 Siena Red, first time we’ve ever seen one in the flesh. First thing we did notice was this must be an early M54 3.0 because it had the M52 exhaust setup with the cats mid way down the car instead of how all M54’s have it up on the manifolds.
We forgot photos of when she first arrived but here she is.
We didn’t hang about today getting the subframe out. Gaz took lead today getting everything out. Inspection photos didn’t show nothing we haven’t seen before. Original BMW stickered ahocks
beam bushes in their normal state, although these bushes were showing a subtle sign of being replaced in the past.
brakes not bad but we do have replacements all round.
shocks, standard dead bump stops.
walk round video
View: https://youtu.be/uEQ_29SEqWw
Now starting disassembly.
some early snapped studs. Nothing to serious to sort.
side bolts came out without a fuss.
roll bar nut took the thread with it.
Nearly ready to drop
she’s out!
we then didn’t hang about getting it all apart.
this arm will need to be repaired, 3 little holes already
beam bushes removed.
we could see at the bottom these bushes weren’t fully pressed home, doubt it would of left BMW like that so these have likely been changed in the passed
worth noting we will be starting a new powder coating process, we’ve started seeing a few zeds we’ve done the last couple of years with spotting of rust in places. We’ve agreed now going forward with the coaters once blasted everything will be Zinc primered before coating.
andyglym
walk round video
View attachment 233875Nearly ready to drop
she’s out!
View attachment 233887View attachment 233889
this arm will need to be repaired, 3 little holes already View attachment 233885
Superb colour 👌
Lee
Z4 Coupe 3.0si
Nice big juicy update. Been working on Tom’s Zed on and off the last 3 days. She’s mostly played ball even if she did nearly use up a whole bottle of propane.
Starting at the front my goal was to get everything removed and the engine hanging on the bar. I always start by plugging the brake lines then remove the shocks.
these bolts needed lots of heat. That’s an 18mm bolt.
lowers also needed lots of heat.
tilt the hub off the shock
Once the shock is out the way and the nuts are loosened next tool of choice is the ball joint splitter, this is the main reason why I get the shock out the way. Job made easy with this tool
Simples :D Next up I remove the tie and track rod. Again a very simple job.
remove the boot
leaves this side clear
Once the wishbone was off, done very easy with a big fork. Your left with a very empty side.
Plenty of under seal left behind
and an empty arch.
Rinse repeat on the other side.
finito
it was at this point while I walked round the car and noticed Barry having a jolly, we must have 6foot jumping snails in Bramley.
Next up steering rack and subframe.
bolts fought like mad and didn’t want to come out. Bit of swearing and talking dirty to it I won!
passenger side engine mount was toast.
subframe out
Part 2 on route. Hit the photo limit =))
Lee
Z4 Coupe 3.0si
Over lapping Friday in the unit into shed open day Saturday we started disassembling all the metal work ready for powder coating. First up both front knuckles.
stripped down quick enough
crispy
both front ABS sensors really stuck.
One fought all the way to snapping.
didn’t resemble an Allen key bolt
moved onto taking the front shocks apart. No life left in these at all.
Next I tackled a little broken exhaust stud with our new fancy freeze spray.
gave it a coating, left it for a minute. One clout with a club hammer, hey presto!
made light work of that.
Under side looking all stripped ready for cleaning. We decided to remove the engine mounts. Found one stuck to the engine mount. Luckily made easy once in the vice.
Tom spent the day cleaning and sealing the rear underside.
diff also got cleaned up and painted. She was in good shape so decided to paint in house.
side job we re hung the TV today :)
powder coat pile is now huge!! We have 3 sets of arms in that pile one set of wide body if anyone needs a set. All this stuff will be getting the new treatment of zinc primer coat before powder coating.
Lots of new bits ready to rock. Tom was on point getting stuff ordered early.
Lowering springs and Sachs Shocks.
Now we wait for everything to come back from the powder coaters.
Dino D
Kent
2.8 Manual
This is lovely looking Z.
o/t alert - like the rims on the Porker in the background…in case you were wondering, the engines in the back though :whistle:
Ps what is the thing floating above the Porker - thought it’s a Panda 4x4 thingy but looks too big :bored:
Tom Holland
Even that snail is being looked after by the dedicated team !
Could not ask for a better response to this huge project. Many thanks and candy wait to see all the new and fresh parts fitted. Cheers!👍
GazHyde
Administrator
Administrator
Z4 MR
More in the middle really, there's boot space at the back 😆 😗
Lee
Z4 Coupe 3.0si
Ah a Boxster, couldn’t afford a proper Porsche then :whistle:
sorry, just prepping myself for Pork ownership one day, going by PH forums. they are like the M Police but x10 worse =))
This is a nice one. 3.2S 1 Owner car. Just need to fix the rear brake lines.
Lee
Z4 Coupe 3.0si
Powder coat got dropped off early Monday and collected after my night shift today. The coaters assure me the parts that have been zinc coated won’t ever rust! This is a result as it’s only an additional £30.
Saturday will be busy :)
Lee
Z4 Coupe 3.0si
Saturday was a good day even if we did have a few set backs. 3/4 arms came back with holes, the coaters should be checking these before they wrap them up… mind boggles.
also hit a snag with the rear wheel bearings, they looked the part but when installing would not fit the inner hub diameter, ever seen this before.
First few snaps show the fuel tank straps fitted.
next up was to install the diff bush.
then the attempt to fit the bearing assembly.
went In fine but the hub and inner race would not have it
so pair of new Meyle bearings on the way. The powder coat all looks great.
not all was lost today. We started rebuilding the front end.
both sides in and torqued
Engine sat back on its own subframe
Rear shocks ready to rock.
various nuts & bolts arrived from BMW so the new exhaust fitted.
Considering the minor setbacks we have made huge progress. Still only a week or two away from finish.
Lee
Z4 Coupe 3.0si
Had a real good couple of days flying solo, could of got more done but I kept having visitors and people wanted coffee :D
First up I completed the front end of Tom’s car, it would be a shed build without some upgrades. First bits were the shields, bearings and brakes.
The callipers.
both sides
then it was some upgraded HnR roll bars.
work well with Meyle Hd hardware
looking smart fitted
Adding sensors
Also added the bar to the rear ready.
while the other arms are away being redone I could at least get one side built. I also took delivery of new rear bearings, the last ones had the wrong inner race size for some bizarre reason. Bearing fitted better this time.
no race hanging out the back :D
now I can fit the handbrake mech and brake assembly.
followed by calliper.
ready to rock now
was a good time to have a break and help out on the guest cars today.
Anyway back to the Z3 :) to give the guys a good head start this weekend I assembled the rear end as much as possible. She’s so close now.
Not much left to do now. Even the next Z3 arrived.
