For Sale Surplus parts
Mazza
Bognor Regis
These have mostly come from the donor car which was a 2001 1.9 M43.. but used RealOem to find part numbers and see if used on other versions.
edit SOLD… Brake Cables…Pair . Part number 34401166055. Fit the wide body versions as these are the slightly longer cables
£20.00 the pair plus carriage.
Starter Motor. Bosch. Part 12411740379. As far as I can see its fits all cars ???
£25.00 plus carriage
Alternator. Valeo. Pt no. 12317509110. Fits M43 1.9 and may fit an M44 1.9. (But check the connections)
£20.00 plus carriage
Coil Pack. Pt no. 12131247281. With the leads that are fitted it Fits M43 1.8 and 1.9. but can also used on M44 1.9. (but you will have to swap the leads over)
£15.00 plus carriage
This is the cover plate for access to the fuel pump ( behind the seat ) Cant find a part number but must be the same part for all cars.
Rust free !!!! And with the gasket intact.
£5.00 plus carriage
Relays and fuses. Various
Relays £5.00 ea plus carriage
Fuses FOC ….just send me a PM with your address and let me know which ones you need
Clutch Slave cylinder. Part no. 21526775924 Used on all versions
bit of rust on the push rod but was working perfectly when I drove the car before breaking it.
£10.00 plus carriage
I will be posting more parts as I sort through them.
AntStark
2002 3.0 Sport
If you want rid of the cables @Mazza I’ll happily take them off you. Can pick up if easier. ..no worries if you want to keep them. Cheers
