TV fix
Mazza
Bognor Regis
Two days ago my Toshiba tv in the conservatory started playing up.
While watching it, for no reason the menu for the signal input would appear and it would start scrolling though them and most times stopped on the AV1 input.
I did check the remote by removing the batteries, but made no difference so the problem must be the tele.
Using the remote you could return it to the TV but it would keep going back to the signal input menu :arghh::arghh:
Anyway, I looked on line and it turns out that this problem is quite common., not just on Toshiba, but Samsung, Panasonic, plus others.
Fortunately its a very simple fix.
Take the back off and disconnect the lead that connects the onboard buttons pcb.
Make sure that when you lay the tv down its on something soft to protect the screen.
I used the cats bed...which she was only too please to donate :whistle:
Loads of screws so did the Ed China cardboard method
The connector just pulled off and I wound it round one of the cable clips to keep it out of the way
This just disconnects the button panel and just means that all the functions are now only on the remote control.
Everything works and the problem has gone away.:):)
I could have taken the pcb off the button assembly to get a part number, and tried to get a replacement, but not really worth it as they will probably cost a fortune and thats if they are actually available.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
The internet is so good for mending thing :)
It helps me out no end , years ago it would of cost you a fortune to have your tv fixed :)
JaydJeen
Oh no, sorry to hear about the trouble with your Toshiba TV in the conservatory! But hey, it's awesome that you did some online research and found a simple fix for the issue!
Slam
North Yorkshire
Zedless. Mini GP 1379
When you can let me know how you do it !
Technology can be a bit finicky sometimes, and it's great to know there are solutions out there. Taking the back off and disconnecting the lead from the onboard buttons PCB sounds like a nifty trick!
By the way, if you're into tech and want some more cool How To Guides and tech-related news, check out multitechverse.com! They've got a bunch of informative articles that might come in handy for future tech adventures!
as400
I have nothing but admiration for people who can take things to bits then put them back together.
If I take something apart some kind of mystical magic occurs that changes the shapes of the parts ensuring reassembly to be impossible, then, to make matters worse some parts simply disappear.
I find watching James May's The Reassembler to be both cathartic and in wonderment entertaining.
