Yet Another Central Locking
Definitely disconnect your battery ( negative side) . Have some heat shrink tubing to slide on before joining and stagger the joint over a few inches otherwise you will end up with a large bulge of the cable in one place.
ps. This may be obvious so no offence if you're aware.;)
jonco
Chester
'98 1.9 Auto
Agree with Tony but you may wish to consider putting some new wiring in the `bendy' area and rejointing in the boot and boot lid. I did this on mine - you double the number of joints but they are away from the stress area.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Just pulled back the cover from the 'loom of doom', nearly all the wires have broken, well on the positive side I don't need to take the door card off. Would I be right in thinking I should disconnect the battery before I start trying to sort this out?
Glad you found the problem :)
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Looks like I'm going to be checking mine out when I'm on my feet again. Can you take soon pics leach?
leach62
Scotland Borders
Z3 2.0
Thanks Guys your help is appreciated and noted. I think I will re-route the wiring not using the route that the manufacturer did. I know it might not look as good but I would rather do the job once. Looked at an old thread on .org. I will let you know how I get on.
Regards Jim
Low Rider
This sounds like my problem i can unlock remotely BUT not lock remotely. I lock with the key doors and boot lock.
leach62
Scotland Borders
Z3 2.0
Hi Guys
Success, the loom of doom has been re-routed and repaired. When I inspected it 7 of the 9 wires had broken. I pulled back as much of the sleeve as I could and found further damage to the wire covering, put heat shrink on that.
Loom re-routed. Heat shrink applied to further damaged area
Wires soldered
Tested and heat shrink applied
Cover replaced and more insulating tape applied. I then punched a small hole in the underside of the lower rubber cover and used a plastic tie to secure the loom.
Regards Jim
GazHyde
Administrator
Administrator
Z4 MR
Top work Jim, it's awesome to see someone who can solder and repair wiring problems correctly. None of that scotch lock rubbish! Looks like that repair should be good for another 15+ years :thumbsup:
leach62
Scotland Borders
Z3 2.0
Gaz Thanks in all fairness there was two of us, but I am hopeful that it will last another 15 years. The car has her 15th birthday next month and I have had her 11 years and there was an immense amount of satisfaction when we had finished.
Regards
Jim
There's always a sense of achievement when you D.I.Y. Jim. Well done.
