- Dec 26, 2016
- Location
- Spaldingski, Lincs
- Model of Z
- 3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
So my 3 litre (2001) Z3 has a terrible ride quality.
It crashes over any imperfection in the road then bounces for a while after. It is tiring to drive and I find myself looking at the road surface more than I should and dodging everything I see. There are a couple of bits of road near my house that I won't drive down as the car feels so bad over them. Not ideal!
My car has small wheels (15") and large sidewall tyres; 65% of 215mm. As they are 215/65. I believe the 'bounciness' is due to the tyres, which I can't do much about apart from changing the pressures, which I have done constantly with little effect.
My car also has new BC coilover springs and dampers. These were necessary to reduce the arch gaps after the new body was fitted. The dampers are fairly basic, so only have adjustment for rebound (or is it pre-load?). The adjustment is on top of the mounts. I have tried the dampers on hard, soft and everywhere in between with little difference. For now I have the dampers dialed right back to their softest settings but the ride is still bad. I think the springs are very stiff, as this type of suspension is aimed at the 'sporty' market.
So I am now thinking the main problem must be with other parts of the suspension; ie pivot joint bushes and things like the beam bushes. I bought a new pair of beam bushes but haven't got them fitted as yet.
I don't have any benchmark for how the car should ride as I never drove it before changing everything. I don't know how good or bad the Z3 should be, but I'm sure it shouldn't be this bad.
I am planning on booking the car in to have the suspension 'checked'. The problem is at present I have to believe everything they will tell me, as I don't know any better.
So....my question is what are the most likely causes of the crashiness and poor ride quality for a 25 year old Z3 (taking the new springs and dampers into account), which presumably hasn't been touched for a long while, if ever? If it helps the front seems worse than the rear, but that may be just because that is the end that hits the road imperfections first?
Also....is there anything I can check myself (without a lift)?
