ASC control
Gremlin
Salisbury
Z3 1.9
Hi can any one tell me is there any way to check if the ASC control is working on my car. I have pressed the button which I assume should light up green but it dose not. I’m also not certain the system is working at all. I know what it’s supposed to do but again how can I find out if it is. Please don’t just say press the button and go for a drive, as I’ve already stuffed the front this week, which is why I don‘t think it’s working. Any help would be appreciated thanks.
Gremlin
Salisbury
Z3 1.9
Press the button and go for a test drive!
hope that helps!
Not really Andy, you just trying to sell me more parts lol. I have pushed that switch before and there is no green light plus I found no difference in how it drives. But that dose not mean it’s working or not. What dose it switch on or off and is there a test that can tell me If it’s even connected.
Bampz
Pembrokeshire
ASC controls the rear wheels spinning on acceleration , I stand to be corrected but I think that i t is to control wheel spin on acceleration on different surfaces ( greasy or loose clippings ect ) , to test find a long layby and light up the rear wheels and see what happens ,I think it working the green light will flash , when safe to do so
Gremlin
Salisbury
Z3 1.9
So the green light dose not stay on permanent after pressing the switch ?. Would you know how it works, is it on the brake sensors ?.
Bampz
Pembrokeshire
I came across this when I was researching my abs issues , so what activates the asc I'm not sure ,sorry
jonco
Chester
'98 1.9 Auto
..... I have pressed the button which I assume should light up green but it dose not........
The button does not light up - the indication is in the centre of the instrument cluster - does that light up on start-up checks?
Edit - may vary with different years - my comment applies to 1998 and earlier.
Oddly Godly
dunstable
z3 2.8
On mine if i press the asc button it lights up the symbol on the dash. It means it is turned off. When on the dash light illuminates only when it is active. Normally when accelerating on a poor surface
Press the button and its turned off and the dash light will be permanently illuminated, if it activates during driving when a loss of traction or stability is sensed it will work automatically and the dash light will flash during operation.
