Hi all,
I'm new to this forum and optimistic that I'm in the right place to get some help! I've got a '98 z3 that used to be a 2.8L car. Long story short, I bought it with a blown engine thinking it would be a good recipient for an N52B30 with 6spd transmission I had. The engine and trans is in the car now, but it sits a little closer to the radiator and the expansion tank no longer fits in the factory location between the rad and cylinder head.
I would like to get some recommendations for where it can be located. From what I can tell, M54 cars had the expansion tank behind the drivers side strut tower. I obviously won't be using the ??cruise control?? module that used to sit there, but I plan to keep the ABS pump. Does anyone know if the M54 expansion tank will fit? Also, I believe the M54 expansion tank has 2 outlets. Do you know if the S54 version has a single outlet?
Finally, I'm happy to hear other recommendations for expansion tanks. I plan to do a write up of the work I did to get the N52 into the car, but I'll wait till I'm a little further along the process. I need to get the EWS deleted on the DME, so I still haven't started it in the car.
Thanks for your help!
