I like the colour combo. very nice,
Yes, don't mind the drive really and it was only about £40 in fuel but I'll wait and see what he says. From what I have looked at I think I will be able to undo the fixings at the front and just pull it forward then redo the fittings that clamp the fabric. The top of the roof is not held down by anything and when it folds the seam is in line with the bar so it looks like it just needs pulling a little tighter.An easy fix to realign to the frame albeit a good few miles to go there and back.
Thanks, I think that is just the photo that makes it look like that, there is part of the frame there which pushes the hood out which is what can be seen in the photo.Looks nice the red, as for fitting I can see at the back as you pointed out but is it more saggy around the drivers relieve pocket compared to the passenger side or is it just the photo?
So just before Christmas I made a 3 hour journey down to Jack Smith Trimmers in Swansea for a new roof. I used the guy in Croydon previously for a blue roof and since then his prices have gone up to just under £400 which was for a black or blue one. This time I wanted something different and decided to go for a red one. Most places want £700 plus for a red roof and I had heard good things about Jack Smith trimmers and he would be able to fit a new red roof for me. All of his reviews were decent although I hadn't seen too many for Z3 roofs so I thought I'd take a chance as he was less then half the price of any others at just £300. He makes them up himself and then fits whilst you wait. He can do a clear or green tinted window just like BMW fit from the factory albeit stitched in and not zipped in. The roofs are made from mohair and the quality is that of OEM and they also have the relief pockets on the rear. It took him around 4 hours to get the old one off and new one on and he cleaned up all the seals before refitting them.
Here's a few pics
There is a slight problem I have at the moment with the way it is fitted as the one side is slightly lower at the rear than the other. You can see this were there is a stitched seam across the rail at the rear (just above the window) where it is not perfectly straight across it where it should be. It is about 1-2cm's out and looks like it needs to be moved forward to sit spot on. He told me to leave it up for a few days to let it stretch and settle in to place but it hasn't really moved which I didn't expect it too but I am waiting for a reply so I might be making a trip back there to get it sorted.
You can see the way it sits slightly lower across the seam on the passenger side.
This is nothing to do with the quality, its just not been fitted 100% but I expect he will sort the problem out for me as he seemed a genuine and honest guy. The usual questions that will come are: Does it have a zipped in window, no. Does it have the relief pockets, yes. Does it still have the headlining fitted (facelift), yes. Will he do different colours, yes. He even said he could make a cream hood but doesn't recommend them due to them becoming discoloured.
Overall I am chuffed with the quality and the way in which the car now has a completely different appearance and I would definitely recommend him if anyone is after a new roof at a great price, despite my fitting issue, but this will be sorted soon I'm sure. For £300 you can't really go that wrong, unless you don't mind wasting an extra £300-£400 for an overpriced fitting fee.
Even got a run out over the Brecon Beacons on the way there and back.
I think the LM's look just fine!!I think that shantybeaters old zed made my mind up to go with red.
Can't wait to see how it looks with my summer wheels back on.
You've got your self a list there which will keep you occupied for hoursWell I got bored and was looking for more things to do with the zed, so have a few things to fit over the next few months, some of which I had for Christmas and bought with Christmas and birthday money. In no particular order but some will be fitted first as they are easiest
New door handle gaskets
Replacement 2nd hand roof seals (front 2 on both sides)
Red Z3 decals to replace the blue ones on the ///M gills to match the roof
Red carbon fibre wrap to redo the satin brushed wrap in the interior, again to match the roof
Drilled and grooved MTEC front and rear discs, new pads and handbrake shoes/fittings (not got pads or fittings yet)
Braided brake hoses
Braided clutch hose
Paint calipers
New dashcam to be fitted
New 5" dash screen and front camera to be fitted in bumper
Accelerator cable
Both intake hoses
M54B30 inlet manifold and throttle body adaptor
Maybe a couple of other bits before the summer and I am also torn between having the lips polished on my LM reps or having the front bumper repainted.
Well I have been thinking about it, infact for the last few winters. They are lacquered so I will need to remove that by sanding it off then going all the way through the grits and finish off with metal polish. It will all need to be done by hand which I am capable of doing, its whether I can be bothered as I know its a long process and it gets a bit boring which is why I'm tempted to let someone else do it. Would be easy if they were genuine as I could split them but I can't and it will be hard getting upto the lip by the bolts.Can you not polish the lips yourself with a drill? Or are they lacquered?
Nice list!
Agree, doesn't sound fun getting laquer off..they look easy enough to keep polished once bare except around the bolts..Well I have been thinking about it, infact for the last few winters. They are lacquered so I will need to remove that by sanding it off then going all the way through the grits and finish off with metal polish. It will all need to be done by hand which I am capable of doing, its whether I can be bothered as I know its a long process and it gets a bit boring which is why I'm tempted to let someone else do it. Would be easy if they were genuine as I could split them but I can't and it will be hard getting upto the lip by the bolts.
