How To Guide INLET CAMSHAFT SENSOR - REPLACEMENT.
I had to replace my inlet camshaft sensor, again, last weekend and if you find yours needs replacing and aren't sure how to do it, here's how.
Firstly, to change it you have to be able to see it.
1. Remove the key from the ignition and put it away from the car.
2. Slacken off the oil filter housing cap by a couple of turns and allow the filter bowl to drain for a few minutes and then completely remove the cap and filter.
3. Ball up some paper towel and fill the filter bowl with it to prevent anything going into the engine, this includes the centre part which I had already unplugged to rebuild.
4. Unplug the wiring connector from the Vanos solenoid and unscrew the solenoid and remove it. Wrap this in a sheet of paper towel to keep it spotlessly clean. Also disconnect the vacuum/breather pipe from the rocker cover and ease it out of the way.
5. You can now see the camshaft sensor which is held in place by a 5mm allen screw. Remove the screw and the sensor simply pulls out of the cylinder head. All you need to do now is trace the cable down to the connection down under the inlet manifold. The cable is 18" - 20" long.
6. Compare the new and old sensors and make sure they are the same, including the cable connectors as these can differ.
7. The fitting is just a reversal of the removal procedure.
8. Once you have the engine running again and have checked for oil leaks you may need to clear any stored codes relating to the camshaft position sensor.
9. These are the only tools needed to do this relatively simple job.
A 36mm socket to remove the oil filter, a small pair of grips to remove the Vanos solenoid. Some 1/4" drive socketry , a 7mm socket for the hose clips to remove my cone air filter to access the cable plug and a 5mm allen socket for the sensor securing screw and a couple of extensions.
Hope this is of help to someone out there. If you need any help please send me a PM.
Brilliant write up @t-tony, thanks ;)
Wow, that's a great write up Tony. I'll add to the list of things to add as an article as soon as the new article system is released!
Aceman
Moderator
Wakefield
///M Roadster
Good write up Tony, I don't remember having to take my oil filter out when I did this on my 2.8 M52TU but might be slightly different on the M54. Here is the article I wrote a few years ago which also explains the procedure for the exhaust sensor too which might help people out.
https://zroadster.org/articles/bmw-z3-m52tu-cam-sensor-replacement.68/
To be honest Ian it can be done without removing the oil filter but for a novice I'm thinking the clearer and easier the better. The exhaust sensor is very simple to swap out.:)
Jon Jeffryes
Crawley, West Sussex
Z3 2.2i Sport
Great write up Tony. I did mine last month and the only difficulty I had was getting the connector to unlatch. It had attached itself rather well to the plug in point and took a good deal of wiggling to get it to release (yes I had pressed the sprung release clip in).
I also found it easier to combine with an oil and filter change as I was removing the oil filter housing it made good sense.
Jon
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Surprised that your sensor packed up again @t-tony . Was it an aftermarket one?
Another tip - When I changed mine I also removed the air intake pipe between the air flow meter and the next joint towards the inlet manifold. This gives better access to get your arm in and remove the sensor plug from the socket.
Hi Bryan, I was led to believe that the one I fitted (just over 1 year ago) was an OE quality item but when I removed it, it appeared that was not the case. However the replacement one was obviously a Bosch item with their trade mark obliterated.
This is the one I removed.
This is the one I put in it's place. You can clearly see that it's Bosch item, and if you google the part number you'll see that's the case.
