Been a good couple of days. Lots of little jobs and some head scratching.
first up building the new lollipop bushes.
next I got some fresh paint on all of the callipers and brackets. These took some serious hours to clean up.
not looking too shabby
Next the diff cover needed some love. New bush and sensor bracket. The insides, clutch pack LSD
fitting the new bush. Very easy in a vice.
refitted, new gasket and bracket also fitted.
then gave the diff a coat of paint. There was some serious corrosion on this diff, looked a lot better than I thought it would.
next was some head scratching. In order to replace the front offside brake line complete to the abs pump the engine would need to be removed. So I joined a new bmw line behind the arch liner, least in the future it will make changing them a lot easier. I ended up doing this both sides.
then the passenger side.
brake flaring tool works wonders, makes it a doddle.
The old lines were seriously past it.
Once they were both sorted I then did a dry run of all the front hardware. I use this as a way to find out what bits I have missing plus if I need to make any modifications. Safe to say everything fitted well, I was missing a lot of fixings though.
both front brake carriers needed the threads cleaning out.
next I assembled the KW front coilovers and trialed them out with everything else in place. Drivers side.
passenger side. I would just like to add not my choice in brake line colour.
these coilovers you can adjust the rebound from the bottom, really smart.
If anyone’s interested in these coilovers here is the model number.
