Multiple misfire on 2litre inline six
The Wexican
Hi there , My inline six has developed a multiple misfire problem on cylinders 1,2,and 3. This fault is random. Sometimes it is a rough idle upon start up from cold and sometimes when running. This was confirmed by having the car diagnosed and plugged in for diagnosis. The car year is a 1999 model and was originally sold in Japan. Has anybody any id as to where I might check to solve this problem?
Thanks,
Mike.
The Wexican
The codes were P0300 Random/Multiple cylinder misfire detected. And
P0173 Fuel Trim Bank 2
P0170. Fuel trim Bank 1
The Wexican
Also P0301, P0302, P0303 all misfires on the relevant cylinder. What are the hoses that are you talking of? Thanks, Mike.
Althulas
Banburyshire
M Roadster
The vacuum hoses, definitely can cause this problem to much air causing a weak mixture also faulty fuel regulator can cause this and a rich mixture plus on the other hand leaky fuel injectors can cause a rich fuel mixture.
I would start with the cheapest things before throwing parts at it. Do a visual inspection of the all the vacuum hoses and a smoke test. If you look on YouTube how to make one or use a bought one. Hopefully someone more experienced can chip in some advice @Pingu @Lee also handy if you have your own code reader pays for itself in a few uses.
Oddly Godly
dunstable
z3 2.8
As above but check plugs and visual inspect the coils. Sometimes you can get oil from a leaky gasket in the plug holes
