New Z3 2.8 owner, rough idle?
keenraven
Hey there! Had my car a few days now, 1997 with 75,000 miles. It’s cold today, and I’m noticing a slight oscillation in rpm at idle — between 1000 and 1200 rpm.
Did a little forum searching, saw mention of O2 sensors and VANOS (though I don’t know what that is!).
I don’t really mind the issue if it’s not going to create larger problems. What steps should I take?
Thanks so much for any advice!
Dre0415
Michigan
E36 Z3 2.8I Manual
I'm willing to bet it's the main intake boot had exact same problem with mine. Give the main intake boot a squeeze and check for cracks. If you see cracks replace it and that should get you back running smooth. O2 sensors really shouldn't cause this type of problem on a 1997. Your definitely going to be looking at some sort of vaccum issue if I had yo guess. Does your issue fix itself when the car warms up?
Dunkelgrun
Maine
Could be any number of things but +1 on checking the intake boot. Mine looked fine from the top but had a big hidden crack on the bottom side... while you are there you can clean the gunk off the throttle body too, that can effect idle. Maybe buy a new gasket first so don’t have to reuse the squashed old one
keenraven
Thank you for the input! I’ll definitely investigate the intake boot. The situation is strange — it has only happened once. I drove it 3-4 times yesterday, with plenty of time for the car to cool down in between; but the issue never reoccurred.
Patryk
Cardiff
I had rough idle only on warm, since I bought the car. Mine had problem with o2 sensors. It turned out that the wiring was literally melted. Someone snapped the cable with gearbox mounting.
