Removing a Stuck Seat
RickyBobby
Sheffield, South Yorkshire
E89
Trying to get the passenger seat out but the electrics have been disconnected and the drive spindles removed - the motor is intact so is there anything else I can use to move the seat forward so I can remove the rear bolts? Thanks.
Geoff Crispin
Somerset
3 1.9 & 3.0
Think I am right in saying that the electrics are the last thing to disconect. Geoff
RickyBobby
E89
To be honest Geoff I was after some advice rather than a statement of the bleeding obvious - no offence intended.
Appreciate all these cars come with history and in respect toT86 KJF the disconnected passenger seat with no ability to recline was simply that. For now I've given up on trying to remove and on the occasion someone wants to join me on a run out they have to accept the fixed driving position ;)
Still hopefull someone will come along with a miracle cure so to speak but I always was the eternal optimist despite my beer glass always being half empty.
Can you use the spindles out of the drivers side? Not sure if you saw my article on removing seats using the spindles. Careful though if you are down to just the drivers ones...
https://zroadster.org/articles/bmw-z3-stuck-seat-motor-seat-removal.21/
I'm sorry but that made me laugh =)) TBH @RickyBobby we have all probably been guilty of this at some point. ;);)
RickyBobby
E89
Like it will give that a go - from you experience is there a high probability I could damage the spindle sufficient so I wouldn't be able to replace it? Irrespective I guess I could always source some replacement spindles via a breaker.
RickyBobby
E89
I hear that brother and to be honest that was the only intention in my comment - as I said no intention to offend but I'm never one to miss an opportunity for a laugh especially if it's not at my expense :)
If you put too much torque through the spindle it will likely buckle, so take it easy paying attention to the direction of winding.
As for getting hold of spindles, you’d need to find a breaker who is stripping the seats apart. That only tends to happen to really whipped sets, as selling the spindles makes the seat unusable.
Mario
Hello - I agree with the reply above, take one of the spindles from the driver side seat, no matter what side and then try inserting it and rotate it slowly on the passenger seat rails with the other end attached to a drill, you will see immediately if the seat would move or not, try both sides see how it goes. if you can't move it with the drill with low / medium force (the spindle will bend/twist slightly) then your only option would be to remove the seat from the lower frame (tricky but doable and then after that use an angle grinder or something similar from above to cut the frame and access the rear bolts.
2bmws
Wales
When i had to remove my passenger seat without electric i manage to power the motor to lift the seat up made access a little easier, undo the two front nuts then in seat runner theres a square flexible rod at the front which goes to the little box things mounted on the rails either side, if you can attach a drill to the rod and wind out each side at a time the seats got to come forward quite a way to reach the bolts underneath, or if you can get the flexible rod out and cut a long piece of metal and cut it to the square size of the flexible rod and attach that to a drill. The fitter in my works made me one out of an alan key.
Mario
I might have one but will need to check ping me on pm and I will have a look tomorrow
deniskapliy
.... if you can't move it with the drill with low / medium force (the spindle will bend/twist slightly) then your only option would be to remove the seat from the lower frame (tricky but doable and then after that use an angle grinder or something similar from above to cut the frame and access the rear bolts.
Hi Mario! I've been struggling to get the driver seat out for a few days now. The right track (the one closer to the center panel) moves using the manual "drill + spindle" method, but the left track is siezed. I upgraded my technique to the milquakee SQ1 bit to be able to transfer more torque to the tiny differential that moves the rail but still no luck (I discovered that there is another spring which then moves the rail. I can feel with my finger that once I start applying force, that second spring starts to twist which leads me to think the rail is siezed for some reason).
You mentioned above that the only other option is to remove the seat from the lower frame. Do you think you could explain the method? I am at a point where I am almost ready to cut the floor from underneath to release the seat.
stewartfield
Hey Denis, did you ever figure this out? I am facing the exact same issue with my 97 and it is making me want to tear my nonexistent hair out.
deniskapliy
Yeah I believe you. They key was to use the milquakee SQ1 square bit (similar concept to what what 2bmws mentioned above), and connecting it directly to the second (further) spindle which sits in the rail itself since trying to move the seat by attaching the drill with the attachment to the silver differential (I don't know if it's called a differential actually but it's the silver looking thing with a green dot in the photo that transfers the torque from the electric motor to the rail) only resulted in the second spindle (the one coming OUT of the differential) buckling because the rail was stuck.
Anyway, I recall removing the second spindle and attaching the square bit directly in its place (which required a long extension too because I have to approach it at slight angle) - this way I could transfer way more torque to the rail vs doing it through the differential and the spindle. Believe it or not, it still took hours of messing with it (with loads of WD40 all across the rail) before it finally gave up and moved.
Good luck, this job is a PITA for sure
stewartfield
Dude you are a saint for posting such an in depth reply so thank you. Did you have to pop that little "differential" out? If so, how did you do it? I can't seem to get anything in there to pry it out.
deniskapliy
No, I didn't remove it. I was able to approach the square hole (circled in the image) with the square bit 'head on' using a long extension, angling slightly upward because, as I am sure you're finding out, it's hard to 'connect' your drill to that hole directly because the differential is in the way. With a longer extension, there is 'play' in the linkage which allowed for enough angle to insert the square bit.
I also remember that it wasn't easy to remove that spindle going from the differential and into the rail. I think I had to pry it out (thankfully, it has some 'give', essentially being a very tight coil). You might want to be really careful there if you're trying to save the spindles (I wasn't because I had a new set of seats ready to go). Still, I am pretty sure I was able to 'save' those spindles when taking them out.
Oh, I also remember hitting s*** with a rubber hammer. A lot.
stewartfield
Denis you are a gentleman and a scholar, thank you man. I managed to get the spindle out, just need the proper bits now, I'll update when I have a chance to get back to this. Thanks for the assistance, I was about ready to get a sawzall and start hacking at it!
stewartfield
Denis,
I FINALLY got it out!!! I had to use an SQ2 but as the hole was a little stripped, but the screw finally turned and the seat is out. The fuel pump was promptly replaced and now I can attempt to start it finally, after so long. Thank you for helping me revive my project man, I was so discouraged. On to the next job!!
