Roof motor
Keavo69
Newton abbot
Z3 2.8 roadster
Hi all
My roof has an intermittent fault when sometimes it doesn’t operate correctly most of the time it’s fine some of the time it only works with the engine running I hav taken a pic of the reservoir should it be topped up if so what fluid should it be
Cheers marv
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift
My reservoir has a very similar amount of fluid in it (maybe even a tad less)
So either both of ours are fine or both need topping up!
The microswitch in the roof and the brake light switch are a known problem. One is much easier to check than the other ;)
Also the cable from the microswitch can break with age as if routes through the roof frame. Very unlikely to be the motor imo
Keavo69
Newton abbot
Z3 2.8 roadster
Thanks for the reply’s
Is there a way of checking that’s it’s the micro switch
