ok eyes down look in for day 2 of holidaying in Costa Del Garage...
So today was mainly braving wet sanding, cutting and polishing the newly clear coated quarters and wings. But first... final two coats of filler primer on the new offside sill cover..
That then has to cure for 24 hours before I can add top coat...and another two days before clear coat... slow business this painting malarkey!
right now the bit that could go horribly wrong..... taking a shiny nearside wing... and sanding it down.... gulp
you can quite clearly see all the orange peel
so it's out with the sanding block and 1500 grit wet & dry... I was too scared to go lower !
The idea is to get it uniform smooth and NOT go through the clear coat....take out the nibs, fish eyes, dust, lumps
et voila
once it's all uniform, you then go onto the cutting compound I used Maguire's as it seems to be the compound of choice
When your polisher is bigger than the part you're polishing !!
wool pad for cutting, foam pad for polishing
cutting compound will get you a smooth shiny finish..... polish then gives you a mirror !
Then onto the rear quarters... same process
cutting compound, then polish
and the offside
given I'd lost most of my bodyweight in sweat... I decided it was time to do something outside.....shove a long lance in some cavities !
now THAT's a big can!
Spent time with the 360 wand and a thin torch to make sure I hit all the areas of the sills and other cavities
750ml can was enough for me to do both sills pretty thoroughly...
so tomorrow I paint the new offside sill. I need to be careful with the 2k clear as once activated only lasts 48 hours... and I need to clear the sill cover, offside wing, a bit of the boot lid and part of the bonnet where the clear had bubbled up.
