QualityAnd yes before you all comment I seem to have a bit of a BMW addictionView attachment 302685
That would be good feels along time since we had oneCould be soon mate.
I have always managed to remove these screws by removing the hub an d accessing the rear of the bolt hole. This gives you a “real” centre to drill out the broken screw, then you can re tap the thread. Even if there is a broken drill bit in there.Also an ABS Sensor. While removing the original, the bolt sheared. I ended up having to drill it out and use helicoil, hence the strip down
Hi Tony,I have always managed to remove these screws by removing the hub an d accessing the rear of the bolt hole. This gives you a “real” centre to drill out the broken screw, then you can re tap the thread. Even if there is a broken drill bit in there.
I wonder who had that problem... Even if there is a broken drill bit in there...
Ant. Do you want me to get it and I’ll post to you?Less bought ..more ‘acquired’
Stopped in at my local dealer today so they could tell me all the parts they don't have in stock ..literally the nearest radiator cap for an M54 engine was in Bristol! (I am in Portsmouth). Anyway, I was in there 2 mins and it’s the only place I parked..when I got home I noticed this ! That wasn’t there yesterday
Bloody new BMW owners !
That’s very kind of you Paul, thanks. I ordered one on t’interweb in the end. On the upside the magic dent man will be here at 10:30 tomorrow.Ant. Do you want me to get it and I’ll post to you?
