Recently had same issue on our BMW E36 323i (M52B25 2.5 ltr 6 pot). Change of camshaft sensor (OEM) has made it drive perfectly again; well worth doing. ![]() |
Bentley's 'Left side' assumes you are sat in the car. Looking from the front you will find it hidden under the Vanos solenoid on the right hand side of the head.Just looked again and definitely not there; Bentley says it is "mounted at left side of cylinder head near front" -
Run the video and stop it at 6.03. The guy is pointing at the inlet camshaft position sensor. Don’t continue to run the engine for long with this fault as you risk unburned fuel going through the Cat(s) which can damage them.Just looked again and definitely not there; Bentley says it is "mounted at left side of cylinder head near front" - under the fuel injector rail cover. I'll have a more in depth look over the weekend.
A (hopefully) final question on the subject, if I leave it as is for the time being, apart from the stalling issue, will this cause damage to the engine?
Simon
