I can put a tick in the delivered column now
Hello,As of today I have 100 sets ready for despatch.
Each set comprises of the following :
N/S and O/S two part tank straps in 4mm mild steel finished in black powder coat.
Qty 4 M6 Nyloc Nuts
Qty 4 M6 BZP Washers
Qty 2 Cable tie anchors
Qty 2 Cable tie M2.5 x 100 black
Qty 3 Nitrile rubber cushions (270mm, 330mm, for O/S and 350mm for N/S). ( can be fitted prior to despatch if required)
Price : £65.00 per set. Plus postage at cost
Please PM me to order/reserve a set.
Please Note:
The Z3M, will require an additional part (which fits to the N/S bracket) and is still in development, but will be available soon.
Happy daysUpdate on the Z3M straps.......
Picked up the machined blocks and the straps that have had two countersunk holes added today.
All looks good.
The stop bracket will be ready on tuesday, then I will take all the bits to get them powder coated.
Screws are on order and should be with me early next week.
I found some longer M6 screws just to set it up and it all checks out dimensionally against the original part.
I will fit the block before sending any out and it will have loctite on the threads. I will also supply a new M6 x 12 hex flanged head bolt that holds the lower strap to it.
