So you can chuck the ear plugs now?
Certainly don't need the radio as loudSo you can chuck the ear plugs now?
Show me a picture or two Jose, I may have a cunning plan.
It does sound much better than the Pioneer head unit I had there before.How does it sound Jose?
The heads look soft, but they are not. I tried to tap a slightly larger torx bit, but it went nowhere. So, I thought I would try a flat screw bit and indent the top and bottom, also no go.Those screw heads look as though they’re quite soft. Plan 1 try gently tapping a Torx bit into the head, or 2 drill the head off, then remove the rest of the screw withe Mole grips once the unit is removed.
I wish I had seen this before I went mental on the screws...@Mus Musculus - this + a tiny drop of superglue - wait 10 minutes - remove. Works every time for me.
Yeah. I know how this goesI wish I had seen this before I went mental on the screws...
Anyway, with the radio out now I will try your suggestion. Thanks.
Note: It's likely I will glue my fingers to something… I always do when using superglue.![]()
I‘d have had those painted before fitting them.
