Rebody Z3 2.8 Based Ferrari 250 Build
Pontrhydyrun - in Crow Valley
@MisterP007 Great build thread.
Can I ask about your retro looking window winder handles. They're switches aren't they? How did you wire them? Did you run new cables into the door or use existing/unused cables?
Any scribbled wiring diagram to share?
Thanks
Ian
MisterP007
German Engineering - Italian Clothes
Tunbridge Wells
Thanks
Ian
Hi there
On the 250 SWB the window winders are bolted on Triumph Herald winders (bolted through the back of the door car) and the windows are operated from momentary on - off - momentary on stainless steel toggle switches in the centre console.
On the 250 Cal they are momentary on - off - momentary on rotary switches bonded to the back of the winders. There is a description in my 250 California build thread somewhere.
Sorry no time to find it for you.
jaguartvr
The wires on the original switches are
Left
brown
grey/red trace
white/green trace
blue
right
brown
grey/red trace
grey/white trace
black/yellow trace
the 4 wires on each switch are as follows:
Drivers switch
Brown.......................... Earth
Black/White................. Close signal to ZKE
Violet/White................. Open signal to ZKE
Grey/Red...................... illumination for switch (+12v on switching lights on)
Passengers switch
Blue/Green................. Close signal to ZKE
White/Green................. Open signal to ZKE
Ignore the illumination wires (if you wish)
Just connect an earth to the signal for the relevant movement, and it will go in that direction for as long as you hold the earth on it.
Wiring for rotary window winders
The door mirror wiring on the doors is
drivers
green/black
blue/black
blue/white
black/white
passenger.
blue/green
blue/white
blue/black
green/black
Rotary handles come from car builder solutions, I use MGB winder handle as they have a screw hole in them so that you can screw the handle to the switch.
The beauty of doing it this way is that you use the door mirror wiring for the switch so utilise the connection auction for the door wiring so no mucking about when you need to remove the door.
Don't forget to wire up an extra window switch for the dashboard to operate the passenger window or you won't be able to reach it.
MisterP007
Tunbridge Wells
A quick update on "The Beastie".
Overheating
Due to overheating issues (header tank exploded during MOT - EEK!), caused by not being able to get the electric fans to switch correctly. I have re-fitted the viscous fan set-up. Whilst I was in there changing the header tank and fan, I tidied up the plumbing, checking all the hoses, radiator, etc. for leaks, flushed and re-filled the coolant, bled the system and hey-presto no overheat issues.
I am getting used to the noise of the viscous fan now, and it does not seem to have blunted the performance much. I do not drive it like I stole it very much anyway, as I would like it to have a long life, and it goes very well without ragging it in any event.
Alarm System
The only remaining issue is the blasted BMW alarm system randomly going off for no reason after the car is locked for 20-minutes. I have tried with no result:
  • Replacing the bonnet alarm switch and making sure it is compressed with the bonnet closed
  • Fixing the bonnet switch plunger in down position with a small screw
  • Disconnecting the bonnet switch completely (Currently like this)
  • Disconnecting the tilt sensor - I thought this had worked but after 2-hours - beep, beep, beep.... (Currently like this)
  • The radio switch has a cable tie around it - is this the right way to do it or should I just disconnect it?
  • The interior sensor is no longer there as the rear view mirror no longer exists - maybe something in the wiring box I replace it with?
I have not checked the door switches yet.
The central locking works fine but I cannot lock the car due to the alarm issues. Not a problem most of the time, as I have secure, indoor parking near home where the car lives when not in use, and when out I always (nearly always) stop for beer/coffee/food where I can park in sight (and to show-off). It is however, a bit of an issue and the insurers may have something to say about it also.
Has anyone found either an aftermarket alarm that works, or a way to disable the BMW set-up?
Enjoying the great weather and the car.
Pingu
Are you still able to use a key to lock the car? If so, use that. It won't set the alarm.
Any aftermarket alarm will work, but may need to be professionally installed to satisfy the insurers.
I have a VIPER alarm, but that was on the car before I got it.
MisterP007
Tunbridge Wells
A few recent pics:
I cannot lock the car with the key as the lock barrel is deleted when installing the mini handles, central-locking only. I think the key can lock the car without setting the alarm but I need to look up how?
Thanks for the input on the alarm.
Pingu
Do you still have the boot lock?
My M Roadster car can be locked from any of the three external locks.
My kit car had the electrics to the door locks disconnected, but the boot lock still has the electrics. I'm sure if I reconnected the main door electrics (and overcame the deadlock problem that meant they had to be disconnected) they would lock as well.
MisterP007
Tunbridge Wells
I have the locking mechanism for the boot (sitting in the boot well) still connected to central locking. I could see if a hidden pull cord connected to the mechanism could be used as a defacto key to open the central locking if deadlocked. Also this may be the cause of the alarm going off as the latch is not closed onto the original latchplate/keep where there is a spigot which depresses the alarm microswitch?
Taking a look at the weekend......
Mr Spocked
Borranis are just too wide, and also horribly expensive.
What you need is..............
Designed for the Z3 kits, bolt on hubs that allow you to fit the space saver in case of a puncture
Can those bolt on hubs be got still for 15” dunlops??
MisterP007
Tunbridge Wells
MisterP007
Tunbridge Wells
AndersFIN
Good luck with the sale, what next? 😁
May I ask you where you sourced the front foglights? Very nice build - I especially like the colour, that’s why I am painting my car with the same colour 😊
Z3 project
Hi I am new to the forum and have read all Your posts on the 250 build. Is the car still for sale ??
